Introducción
The motherboard is one of the most important components of any electronic device. Damage to the motherboard could result for a variety of reasons. Replacing it may be the best option to get your Vivoactive back to running like new.
The Garmin team did a fantastic job backing a lot of punch into this tiny board, some of the most notable components are:
- GPS and GLONASS antenna
- Bluetooth antenna
- Heartbeat Sensor antenna
- Non-Volatile Flash Memory and RAM
If you're having problems with any of these components, you should consider following this replacement guide for a solution.
Qué necesitas
Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
Place a heated iOpener over the display to loosen the adhesive.
After about a minute, the iOpener may be removed.
Follow previous guides until you've exposed the battery as shown.
Begin by removing the battery connector tab.
2 personas más completaron esta guía.
2 comentarios
Only <3 months, the motherboard is gone?
Do you have any service shop where I can mail for repairing? I am not going to mail order a motherboard and install by myself every 3 months.
Ming
