Saltar al contenido principal
Garmin Vivoactive HR Display Replacement
Qué necesitas
  1. Garmin Vivoactive HR Display Replacement, Display: paso 1, imagen 1 de 1
    • Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
  2. Garmin Vivoactive HR Display Replacement: paso 2, imagen 1 de 1
    • Insert a spudger between the display and watch body.
    • Pry upwards and work the spudger around the perimeter of the display to free it from the body.
    • The display is still attached with ribbon cables so don't remove completely.
  3. Garmin Vivoactive HR Display Replacement: paso 3, imagen 1 de 1
    • Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
  4. Garmin Vivoactive HR Display Replacement: paso 4, imagen 1 de 2 Garmin Vivoactive HR Display Replacement: paso 4, imagen 2 de 2
    • Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
Conclusión
16 personas más completaron esta guía.
Chris Corry
Miembro Desde 07/05/18
256 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G5, Harley Summer 2018 Miembro de IUPUI, Team S2-G5, Harley Summer 2018
IUPUI-HARLEY-SU18S2G5
3 Miembros
3 Guías creadas
19 comentarios
Hello,
thanks for this. Where can i buy the new screen?
Bowland Olan - Contestar
Nice guide! Thanks. But I can’t find any parts to repair my watch
Christoph Freydank - Contestar
Yeah, where can we get the parts from? Also how hard is it to change the battery? Thanks for your help :)
Rick - Contestar
What type of glue i use to connect the display an the body?
culibrkboj - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 18
Ultimos 30 días: 76
Todo El Tiempo: 25,673
