Saltar al contenido principal
Garmin StreetPilot c330 Speakers Replacement
Qué necesitas
  1. Garmin StreetPilot c330 Speakers Replacement, Outer Casing: paso 1, imagen 1 de 3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: paso 1, imagen 2 de 3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: paso 1, imagen 3 de 3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Speakers Replacement: paso 2, imagen 1 de 3 Garmin StreetPilot c330 Speakers Replacement: paso 2, imagen 2 de 3 Garmin StreetPilot c330 Speakers Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Speakers Replacement: paso 3, imagen 1 de 2 Garmin StreetPilot c330 Speakers Replacement: paso 3, imagen 2 de 2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Speakers Replacement: paso 4, imagen 1 de 3 Garmin StreetPilot c330 Speakers Replacement: paso 4, imagen 2 de 3 Garmin StreetPilot c330 Speakers Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Speakers Replacement: paso 5, imagen 1 de 1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Speakers Replacement, Battery: paso 6, imagen 1 de 3 Garmin StreetPilot c330 Speakers Replacement, Battery: paso 6, imagen 2 de 3 Garmin StreetPilot c330 Speakers Replacement, Battery: paso 6, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Speakers Replacement: paso 7, imagen 1 de 3 Garmin StreetPilot c330 Speakers Replacement: paso 7, imagen 2 de 3 Garmin StreetPilot c330 Speakers Replacement: paso 7, imagen 3 de 3
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
  8. Garmin StreetPilot c330 Speakers Replacement, Speakers: paso 8, imagen 1 de 2 Garmin StreetPilot c330 Speakers Replacement, Speakers: paso 8, imagen 2 de 2
    • Carefully use the spudger to pry the speakers from the outer casing.
    • Once removed, you may use a soldering iron to remove the wires from the speakers.
Conclusión
Michael
Miembro Desde 10/07/10
107 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 22-1, Maness Fall 2010 Miembro de Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,733
