Saltar al contenido principal
Garmin StreetPilot c330 Screen Replacement
Qué necesitas
  1. Garmin StreetPilot c330 Screen Replacement, Outer Casing: paso 1, imagen 1 de 3 Garmin StreetPilot c330 Screen Replacement, Outer Casing: paso 1, imagen 2 de 3 Garmin StreetPilot c330 Screen Replacement, Outer Casing: paso 1, imagen 3 de 3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Screen Replacement: paso 2, imagen 1 de 3 Garmin StreetPilot c330 Screen Replacement: paso 2, imagen 2 de 3 Garmin StreetPilot c330 Screen Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Screen Replacement: paso 3, imagen 1 de 2 Garmin StreetPilot c330 Screen Replacement: paso 3, imagen 2 de 2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Screen Replacement: paso 4, imagen 1 de 3 Garmin StreetPilot c330 Screen Replacement: paso 4, imagen 2 de 3 Garmin StreetPilot c330 Screen Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Screen Replacement: paso 5, imagen 1 de 1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Screen Replacement, Screen: paso 6, imagen 1 de 3 Garmin StreetPilot c330 Screen Replacement, Screen: paso 6, imagen 2 de 3 Garmin StreetPilot c330 Screen Replacement, Screen: paso 6, imagen 3 de 3
    • Remove the three screws holding the motherboard in place.
  7. Garmin StreetPilot c330 Screen Replacement: paso 7, imagen 1 de 1
    • Use the spudger to lift up the motherboard.
  8. Garmin StreetPilot c330 Screen Replacement: paso 8, imagen 1 de 3 Garmin StreetPilot c330 Screen Replacement: paso 8, imagen 2 de 3 Garmin StreetPilot c330 Screen Replacement: paso 8, imagen 3 de 3
    Comprar
    • To remove the ribbon cable, lift the black latch using the spudger tool.
    • Separate the connection using either your fingers, tweezers, or the spudger.
  9. Garmin StreetPilot c330 Screen Replacement: paso 9, imagen 1 de 2 Garmin StreetPilot c330 Screen Replacement: paso 9, imagen 2 de 2
    • Slide the spudger under the two flexible tabs located on the right and left sides of the bottom of the screen.
    • Rotate the spudger outward until the tabs are no longer holding the screen.
    • When reassembling, slide the bottom of the screen under the two permanent tabs.
    • Push the screen out from the front.
  10. Garmin StreetPilot c330 Screen Replacement: paso 10, imagen 1 de 1
    • Separate the screen from the front cover.
Conclusión
Adrian Leon
Miembro Desde 10/07/10
173 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 22-1, Maness Fall 2010 Miembro de Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,559
