Saltar al contenido principal
Garmin StreetPilot c320 Speakers Replacement
Qué necesitas
  1. Garmin StreetPilot c320 Speakers Replacement, Rear Case Assembly: paso 1, imagen 1 de 2 Garmin StreetPilot c320 Speakers Replacement, Rear Case Assembly: paso 1, imagen 2 de 2
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 Speakers Replacement: paso 2, imagen 1 de 2 Garmin StreetPilot c320 Speakers Replacement: paso 2, imagen 2 de 2
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 Speakers Replacement: paso 3, imagen 1 de 1
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
  4. Garmin StreetPilot c320 Speakers Replacement, Battery: paso 4, imagen 1 de 1
    • Do not disconnect the black wire. Doing so may cause severe damage to your device.
    • Remove the two #00 Phillips screws securing the battery to the rear case assembly.
  5. Garmin StreetPilot c320 Speakers Replacement: paso 5, imagen 1 de 2 Garmin StreetPilot c320 Speakers Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to peel back the battery bracket.
    • Cautiously grasp the battery and lift it out of the device.
  6. Garmin StreetPilot c320 Speakers Replacement, Speakers: paso 6, imagen 1 de 1
    • The speakers are nestled along the sides of the rear case assembly.
  7. Garmin StreetPilot c320 Speakers Replacement: paso 7, imagen 1 de 1
    • Carefully heat and desolder the speaker lead wires from the back of each individual speaker.
    • The speaker lead wires are the white and brown wires.
    • For help with soldering check out this guide.
  8. Garmin StreetPilot c320 Speakers Replacement: paso 8, imagen 1 de 1
    • Use the flat edge of a spudger to pry each speaker from its housing in the rear case assembly.
    • The speaker lead wires are still attached to the speaker, however they should have been desoldered in the previous step.
Conclusión
Arturo Barajas
Miembro Desde 01/18/12
11 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-19, Maness Winter 2012 Miembro de Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 9
Todo El Tiempo: 1,086
