Saltar al contenido principal
Garmin StreetPilot c320 Rear Case Assembly Replacement
Qué necesitas
  1. Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: paso 1, imagen 1 de 2 Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: paso 1, imagen 2 de 2
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 Rear Case Assembly Replacement: paso 2, imagen 1 de 2 Garmin StreetPilot c320 Rear Case Assembly Replacement: paso 2, imagen 2 de 2
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 Rear Case Assembly Replacement: paso 3, imagen 1 de 1
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Conclusión
Andrew Burman
Miembro Desde 01/18/12
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-19, Maness Winter 2012 Miembro de Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 1,373
