Introducción
For this guide you will be opening the device, but it is fairly simple. Before you begin disassembling the device, be sure the power is off.
Qué necesitas
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
Casi Terminas!
Conclusión
