Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Before disassembling anything be sure that the device is powered off. This installation is much easier for those familiar with the use of soldering irons. Those who have never used one before should look at this guide.
  1. Wedge a plastic opening tool in between the outer frame and the rear panel assembly. Pry the outer frame off the perimeter of the rear panel assembly.
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly. Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  4. Gently pull the battery cable connector from its socket on the motherboard.
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
  5. Do not disconnect the black wire. Doing so may cause severe damage to your device.
    • Do not disconnect the black wire. Doing so may cause severe damage to your device.
    • Remove the two #00 Phillips screws securing the battery to the rear case assembly.
  6. Use a plastic opening tool to peel back the battery bracket. Cautiously grasp the battery and lift it out of the device.
    • Use a plastic opening tool to peel back the battery bracket.
    • Cautiously grasp the battery and lift it out of the device.
Conclusión
Arturo Barajas
Miembro Desde 18/01/12
11 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-19, Maness Winter 2012 Miembro de Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Miembros
4 Guías creadas
Where can I purchase a new Garmin StreetPilot c320 Battery Replacement battery?
john Lyons
11 Cavanaugh Cres
Terrace Bay Ontario
P0T2W0 Canada
John Lyons - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 2,291
