Saltar al contenido principal
Introducción
A step-by-step guide to replacing the antenna in the Garmin Nuvi 680.
Partes
No se especificaron partes.
  1. Garmin Nuvi 680 Antenna Replacement, Outer Case: paso 1, imagen 1 de 1
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Garmin Nuvi 680 Antenna Replacement: paso 2, imagen 1 de 1
    • Remove the antenna cover.
  3. Garmin Nuvi 680 Antenna Replacement: paso 3, imagen 1 de 1
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Garmin Nuvi 680 Antenna Replacement: paso 4, imagen 1 de 2 Garmin Nuvi 680 Antenna Replacement: paso 4, imagen 2 de 2
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Garmin Nuvi 680 Antenna Replacement: paso 5, imagen 1 de 1
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Garmin Nuvi 680 Antenna Replacement: paso 6, imagen 1 de 2 Garmin Nuvi 680 Antenna Replacement: paso 6, imagen 2 de 2
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Garmin Nuvi 680 Antenna Replacement, Antenna: paso 7, imagen 1 de 2 Garmin Nuvi 680 Antenna Replacement, Antenna: paso 7, imagen 2 de 2
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
Conclusión
Chris Marzano
Miembro Desde 20/01/11
968 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 5-22, Amido Winter 2011 Miembro de Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 Miembros
7 Guías creadas
Un comentario
Where can you find the replacment antenna?
All I see is external antennas on the net.
Dennis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 4,346
