Saltar al contenido principal
Garmin Nuvi 65LM Screen Replacement
Qué necesitas
  1. Garmin Nuvi 65LM Screen Replacement, Plastic device casing: paso 1, imagen 1 de 2 Garmin Nuvi 65LM Screen Replacement, Plastic device casing: paso 1, imagen 2 de 2
    • Place the device on a flat surface with the screen facing down.
    • Remove the four 4.80 mm T5 screws on the corners of the device with a T5 Torx screwdriver.
  2. Garmin Nuvi 65LM Screen Replacement: paso 2, imagen 1 de 2 Garmin Nuvi 65LM Screen Replacement: paso 2, imagen 2 de 2
    • There is a ribbon cable that will still connect the front and back panels once they are pried part.
    • Use the plastic opening tool to gently pry apart the front and back casing panels. Repeat this at multiple locations around the edge of the device. You should hear the clips that hold the front and back together pop apart.
    • Once there is a large gap between the from and back casing panels, use your hands to separate the two halves.
  3. Garmin Nuvi 65LM Screen Replacement: paso 3, imagen 1 de 3 Garmin Nuvi 65LM Screen Replacement: paso 3, imagen 2 de 3 Garmin Nuvi 65LM Screen Replacement: paso 3, imagen 3 de 3
    • Use a spudger to pop up the ZIF connector tab that fastens the ribbon cable to the motherboard.
    • Gently pull the front panel away and set it on your flat work surface.
  4. Garmin Nuvi 65LM Screen Replacement, Screen: paso 4, imagen 1 de 2 Garmin Nuvi 65LM Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Use the flat end the spudger to push back the casing clips that hold the screen onto the front casing.
    • Apply light pressure to the front of the screen as you push the casing clips back. This will keep the clips from clicking back into place.
    • Once all clips are pushed back, the screen will easily lift away from the front casing panel.
Conclusión
James Crocitto
Miembro Desde 04/23/15
125 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-3, Amido Spring 2015 Miembro de Cal Poly, Team 15-3, Amido Spring 2015
CPSU-AMIDO-S15S15G3
4 Miembros
6 Guías creadas
Un comentario
Hi where I can get nuvi65lmt screen
ganesh bhattarai - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 1,975
