Saltar al contenido principal
Garmin Nuvi 65LM Car Charger Fuse Replacement
Qué necesitas
  1. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: paso 1, imagen 1 de 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: paso 1, imagen 2 de 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: paso 1, imagen 3 de 3
    • Hold the car charger with your hands so the metal tip is facing towards you.
    • Insert the flat end of the spudger into the slotted grove of the black plastic surrounding the metal tip by pressing down on the tip.
    • Simultaneously press down and turn the spudger counter-clockwise 90 degrees to unlock the black plastic cap.
  2. Garmin Nuvi 65LM Car Charger Fuse Replacement: paso 2, imagen 1 de 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: paso 2, imagen 2 de 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: paso 2, imagen 3 de 3
    • Carefully take off the black plastic cap surrounding the charging tip with your hands.
    • Use your hands to pull off the silver metal tip away from the charger.
  3. Garmin Nuvi 65LM Car Charger Fuse Replacement: paso 3, imagen 1 de 1
    • Turn the charger compartment over and carefully dump the fuse into your hand.
Conclusión
Kai Ling Liang
Miembro Desde 04/26/15
246 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-3, Amido Spring 2015 Miembro de Cal Poly, Team 15-3, Amido Spring 2015
CPSU-AMIDO-S15S15G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 2,074
