Saltar al contenido principal
Garmin Nuvi 56LMT Speaker Replacement
Qué necesitas
  1. Garmin Nuvi 56LMT Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Power off you Garmin Nuvi before disassembling.
    • Use the T5 torx screwdriver to remove the four 11.0 mm screws.
  2. Garmin Nuvi 56LMT Speaker Replacement: paso 2, imagen 1 de 2 Garmin Nuvi 56LMT Speaker Replacement: paso 2, imagen 2 de 2
    • locate the crevice between the front and back panel.
    • Use the plastic opening tool to wedge the device open.
    • Carefully disconnect the ribbon from the ZIF connector.
  3. Garmin Nuvi 56LMT Speaker Replacement: paso 3, imagen 1 de 2 Garmin Nuvi 56LMT Speaker Replacement: paso 3, imagen 2 de 2
    • Locate the two 5.0 mm screws and use the T5 Torx screwdriver to remove them.
    • These screws are easily lost so keep track of them.
    • Once the screws are removed flip the motherboard over and locate the blue (+) and black (-) wires connected to the speaker.
  4. Garmin Nuvi 56LMT Speaker Replacement: paso 4, imagen 1 de 2 Garmin Nuvi 56LMT Speaker Replacement: paso 4, imagen 2 de 2
    • Use the crimping tool to cut the wires from the motherboard.
    • Use plastic opening tool or fingers to remove the speaker.
  5. Garmin Nuvi 56LMT Speaker Replacement: paso 5, imagen 1 de 1
Conclusión
Dustin Saxon
Miembro Desde 09/28/17
228 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S3-G5, Nance Fall 2017 Miembro de USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 114
