Saltar al contenido principal
Garmin Nuvi 56LMT Display Screen Replacement
Qué necesitas
  1. Garmin Nuvi 56LMT Display Screen Replacement, Display Screen: paso 1, imagen 1 de 1
    • Power down the device before proceeding.
    • Locate the four 11.0 mm Torx screws and remove them with the T5 Torx screwdriver.
  2. Garmin Nuvi 56LMT Display Screen Replacement: paso 2, imagen 1 de 1
    • Find the crevice where the front and back of the device meet.
  3. Garmin Nuvi 56LMT Display Screen Replacement: paso 3, imagen 1 de 1
    • Run the plastic opening tool around the border of the device until it can be easily pried open by hand.
    • Be careful to not damage the ribbon cable by completely pulling the back from the front.
  4. Garmin Nuvi 56LMT Display Screen Replacement: paso 4, imagen 1 de 1
    • Carefully use the spudger to flip open the ZIF connector.
  5. Garmin Nuvi 56LMT Display Screen Replacement: paso 5, imagen 1 de 2 Garmin Nuvi 56LMT Display Screen Replacement: paso 5, imagen 2 de 2
    • With your fingers hold back each of the clips located around the border of the screens back.
    • Pull screen up and slide out in the opposite direction of the ribbon to avoid snapping the fixed clips.
Conclusión
Una persona más ha completado esta guía.
Dustin Saxon
Miembro Desde 09/28/17
228 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S3-G5, Nance Fall 2017 Miembro de USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 267
