Saltar al contenido principal
Garmin Nuvi 56LMT Battery Replacement
Qué necesitas
  1. Garmin Nuvi 56LMT Battery Replacement, Battery: paso 1, imagen 1 de 2 Garmin Nuvi 56LMT Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Before disassembling, power off the device.
    • There are four 11.0 mm screws located at each corner on the back of the device.
    • With the T5 torx screwdriver, remove these screws and set aside in a safe place.
  2. Garmin Nuvi 56LMT Battery Replacement: paso 2, imagen 1 de 3 Garmin Nuvi 56LMT Battery Replacement: paso 2, imagen 2 de 3 Garmin Nuvi 56LMT Battery Replacement: paso 2, imagen 3 de 3
    • Using the plastic opening tool, pry apart the device around the seam.
  3. Garmin Nuvi 56LMT Battery Replacement: paso 3, imagen 1 de 3 Garmin Nuvi 56LMT Battery Replacement: paso 3, imagen 2 de 3 Garmin Nuvi 56LMT Battery Replacement: paso 3, imagen 3 de 3
    • Observe the ribbon connecting the screen to the circuit board.
    • Detach the clip using the plastic opening tool and set aside the screen.
  4. Garmin Nuvi 56LMT Battery Replacement: paso 4, imagen 1 de 3 Garmin Nuvi 56LMT Battery Replacement: paso 4, imagen 2 de 3 Garmin Nuvi 56LMT Battery Replacement: paso 4, imagen 3 de 3
    • Using the T5 Torx screwdriver, remove the two remaining 5.0 mm screws.
    • Lift the board from its housing and then detach the plug coming from the battery.
  5. Garmin Nuvi 56LMT Battery Replacement: paso 5, imagen 1 de 1
    • If the battery is glued in place use the plastic opening tool to remove it.
    • Finally, exchange the old battery with the replacement.
Conclusión
Equipo
USF Tampa, Team S3-G5, Nance Fall 2017 Miembro de USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 23
Todo El Tiempo: 440
