Saltar al contenido principal
Garmin Nuvi 50LM Power Button Replacement
Qué necesitas
  1. Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: paso 1, imagen 1 de 2 Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: paso 1, imagen 2 de 2
    • Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
  2. Garmin Nuvi 50LM Power Button Replacement: paso 2, imagen 1 de 2 Garmin Nuvi 50LM Power Button Replacement: paso 2, imagen 2 de 2
    • Pry open the device from all four sides using the iFixit Plastic Opening Tool until you see the inside of the system.
  3. Garmin Nuvi 50LM Power Button Replacement: paso 3, imagen 1 de 2 Garmin Nuvi 50LM Power Button Replacement: paso 3, imagen 2 de 2
    • Look for a small button on the motherboard at the top of the device, and insert replacement power button on top of the small button on the motherboard until you hear a click.
Conclusión
2 personas más completaron esta guía.
Maurice Thomas
Miembro Desde 10/13/15
664 Reputación
5 Guías creadas
Equipo
3 comentarios
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
Denny Manning - Contestar
The power button on my Garmin 50 LM fell off the other day. I can’t find anywhere where I can buy a new replacement. Any suggestions would be much appreciated. Thank you!
Mary - Contestar
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
Erik Pistek - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 36
Todo El Tiempo: 7,034
