Introducción
In this guide the repairer replaces the auxiliary audio out port of the device by disassembling to expose the motherboard and desoldering the component.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
- Fine Point Tweezers
- Spudger
- Soldering Iron
- Solder Extraction Tool
- Copper Braid
- Solder Sucker
Estimated Duration: 15 minutes
Qué necesitas
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
De-solder the audio out port. Use a soldering iron to melt the solder on each of the leads of the port and a solder extraction tool (not shown), such as a solder sucker or copper braid.
