Saltar al contenido principal
Garmin Nuvi 265WT Screen Replacement
Qué necesitas
  1. Garmin Nuvi 265WT Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Remove PN/Model sticker an the lower side of the device.
    • Use pentalobe screwdriver to remove the two screws underneath it.
    • Use the nylon spudger to remove the screen from the device.
    • The regular black nylon spudger should be used whenever possible, especially around glass displays and other sensitive components.
  2. Garmin Nuvi 265WT Screen Replacement: paso 2, imagen 1 de 1
    • Lift up the screen gently and place it on the opposite side.
  3. Garmin Nuvi 265WT Screen Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool to gently lift up the white rectangular snap clip that is attached to the screen.
  4. Garmin Nuvi 265WT Screen Replacement: paso 4, imagen 1 de 1
    • Lift up the screen and you're done.
Conclusión
Equipo
Texas Tech, Team 6-4, Bennett Fall 2016 Miembro de Texas Tech, Team 6-4, Bennett Fall 2016
TTU-BENNETT-F16S6G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 447
