Saltar al contenido principal
Garmin Nuvi 2597LMT Microphone Replacement
Qué necesitas
  1. Garmin Nuvi 2597LMT Microphone Replacement, Microphone: paso 1, imagen 1 de 2 Garmin Nuvi 2597LMT Microphone Replacement, Microphone: paso 1, imagen 2 de 2
    • Turn your device over so the back is revealed and you can see the screws in the four corners.
    • Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
  2. Garmin Nuvi 2597LMT Microphone Replacement: paso 2, imagen 1 de 3 Garmin Nuvi 2597LMT Microphone Replacement: paso 2, imagen 2 de 3 Garmin Nuvi 2597LMT Microphone Replacement: paso 2, imagen 3 de 3
    • Use the plastic opening tool to pry open the device at the seam where the two halves meet, prying all along all sides if need be.
    • Do it slowly so you don't accidently rip the ribbon cable that connects the digitizer to the motherboard, as well as don't completely separate the halves as this can tear the ribbon cable.
    • Open your device from the top, so that you don't disconnect the ribbon cable.
  3. Garmin Nuvi 2597LMT Microphone Replacement: paso 3, imagen 1 de 3 Garmin Nuvi 2597LMT Microphone Replacement: paso 3, imagen 2 de 3 Garmin Nuvi 2597LMT Microphone Replacement: paso 3, imagen 3 de 3
    • Use your soldering iron to disconnect the wires from the motherboard. Disconnect the ground wire (the black one) and the positive wire (the red one).
    • The soldering iron is very hot and do not touch the wires to anything as it may stick to it when it cools.
  4. Garmin Nuvi 2597LMT Microphone Replacement: paso 4, imagen 1 de 2 Garmin Nuvi 2597LMT Microphone Replacement: paso 4, imagen 2 de 2
    • Use your hands to grab the wires, and gently pull the microphone up and out of the casing.
    • After this step is complete, you can safely set the removed microphone aside.
Conclusión
Patrick McNett
Miembro Desde 10/03/16
887 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-4, Sullivan Fall 2016 Miembro de USF Tampa, Team 1-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G4
4 Miembros
5 Guías creadas
2 comentarios
Where do I buy a new microphone?
Rich Hollabaugh - Contestar
Good question! I think that the mic on my Nuvi 465W "ist kaput", but Garmin does not sell any internal replacement components!
Jack McGhee - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 572
