Saltar al contenido principal
Garmin Nuvi 2595LMT LCD Screen Replacement
Qué necesitas
  1. Garmin Nuvi 2595LMT LCD Screen Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: paso 1, imagen 1 de 1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT LCD Screen Replacement: paso 2, imagen 1 de 2 Garmin Nuvi 2595LMT LCD Screen Replacement: paso 2, imagen 2 de 2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT LCD Screen Replacement: paso 3, imagen 1 de 3 Garmin Nuvi 2595LMT LCD Screen Replacement: paso 3, imagen 2 de 3 Garmin Nuvi 2595LMT LCD Screen Replacement: paso 3, imagen 3 de 3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 2 Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: paso 4, imagen 2 de 2
    • Grabbing the top half of the Nuvi, remove the screen from the tabs holding it in place using thumbs.
    • Place screen on table.
  5. Garmin Nuvi 2595LMT LCD Screen Replacement: paso 5, imagen 1 de 2 Garmin Nuvi 2595LMT LCD Screen Replacement: paso 5, imagen 2 de 2
    • Place new screen in proper position, with the ribbon facing downward.
Conclusión
2 personas más completaron esta guía.
3 comentarios
cannot prise open the connector to replace ribbon
norman bayne - Contestar
My screen is cracked. The screen opens, but I can't use the key board.
Thank You For any Help You Can Give Me,
Cookie
cookiecaafato1@yahoo.com nuvi 2595 LMT
cookiecalafato1 - Contestar
Re-seating the ribbon is simply impossible.
daBee - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 15
Todo El Tiempo: 4,611
