Saltar al contenido principal
Garmin Nuvi 2595LMT GPS Mount Replacement
Qué necesitas
  1. Garmin Nuvi 2595LMT GPS Mount Replacement, GPS Mount: paso 1, imagen 1 de 1
    • Separate the GPS mounting cradle from the mounting device.
  2. Garmin Nuvi 2595LMT GPS Mount Replacement: paso 2, imagen 1 de 1
    • Gently remove the cradle from GPS device.
    • [Reassembly tip: Place the cradle so that the triangle on the back is facing upwards. Align the GPS and cradle so the inserts and tabs of the GPS are in line with one another.]
  3. Garmin Nuvi 2595LMT GPS Mount Replacement: paso 3, imagen 1 de 1
    • Pull the lever on the back of the GPS mount up and remove it from the surface.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,235
