Saltar al contenido principal
Garmin Nuvi 2595LMT Back Cover Replacement
Qué necesitas
  1. Garmin Nuvi 2595LMT Back Cover Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: paso 1, imagen 1 de 1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT Back Cover Replacement: paso 2, imagen 1 de 2 Garmin Nuvi 2595LMT Back Cover Replacement: paso 2, imagen 2 de 2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT Back Cover Replacement: paso 3, imagen 1 de 3 Garmin Nuvi 2595LMT Back Cover Replacement: paso 3, imagen 2 de 3 Garmin Nuvi 2595LMT Back Cover Replacement: paso 3, imagen 3 de 3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 887
