Saltar al contenido principal
Garmin Nuvi 2557LMT Disassembly
Qué necesitas
  1. Garmin Nuvi 2557LMT Disassembly, Garmin Nuvi 2557LMT Disassembly: paso 1, imagen 1 de 1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Disassembly: paso 2, imagen 1 de 1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Disassembly: paso 3, imagen 1 de 1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Disassembly: paso 4, imagen 1 de 2 Garmin Nuvi 2557LMT Disassembly: paso 4, imagen 2 de 2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 1,327
