Saltar al contenido principal
Garmin Nuvi 2455LMT Speaker Replacement
Qué necesitas
  1. Garmin Nuvi 2455LMT Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver. Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Speaker Replacement: paso 2, imagen 1 de 2 Garmin Nuvi 2455LMT Speaker Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
  3. Garmin Nuvi 2455LMT Speaker Replacement: paso 3, imagen 1 de 3 Garmin Nuvi 2455LMT Speaker Replacement: paso 3, imagen 2 de 3 Garmin Nuvi 2455LMT Speaker Replacement: paso 3, imagen 3 de 3
    • Open the device carefully being weary of the orange band that is going from the screen to the mother board.
  4. Garmin Nuvi 2455LMT Speaker Replacement: paso 4, imagen 1 de 2 Garmin Nuvi 2455LMT Speaker Replacement: paso 4, imagen 2 de 2
    • Using the plastic prying tool, carefully pry the speaker from the plastic backing.
    • Remove the speaker from the motherboard by gently pulling on the wire.
Conclusión
Equipo
USF Tampa, Team 2-3, Blackwell Fall 2016 Miembro de USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 210
