Saltar al contenido principal
Garmin Nuvi 2455LMT Back Panel Assembly Replacement
Qué necesitas
  1. Garmin Nuvi 2455LMT Back Panel Assembly Replacement, Back Panel Assembly: paso 1, imagen 1 de 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: paso 2, imagen 1 de 2 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: paso 3, imagen 1 de 3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: paso 3, imagen 2 de 3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: paso 3, imagen 3 de 3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 2-3, Blackwell Fall 2016 Miembro de USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 974
