Saltar al contenido principal
Garmin Nuvi 200w Screen Replacement
Qué necesitas
  1. Garmin Nuvi 200w Screen Replacement, Rear Cover: paso 1, imagen 1 de 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: paso 1, imagen 2 de 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: paso 1, imagen 3 de 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Screen Replacement: paso 2, imagen 1 de 1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Screen Replacement: paso 3, imagen 1 de 3 Garmin Nuvi 200w Screen Replacement: paso 3, imagen 2 de 3 Garmin Nuvi 200w Screen Replacement: paso 3, imagen 3 de 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Screen Replacement: paso 4, imagen 1 de 2 Garmin Nuvi 200w Screen Replacement: paso 4, imagen 2 de 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Screen Replacement, Display Assembly: paso 5, imagen 1 de 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: paso 5, imagen 2 de 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: paso 5, imagen 3 de 3
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
  6. Garmin Nuvi 200w Screen Replacement, Screen: paso 6, imagen 1 de 3 Garmin Nuvi 200w Screen Replacement, Screen: paso 6, imagen 2 de 3 Garmin Nuvi 200w Screen Replacement, Screen: paso 6, imagen 3 de 3
    • Using your plastic opening tool, apply pressure on the top right of the screen in order to remove some of the tabs.
    • Work the plastic opening tool around the whole screen to remove the tabs from the screen.
    • Carefully separate the screen from the front cover.
Conclusión
Matthew Eires
Miembro Desde 03/08/17
319 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 353
