Saltar al contenido principal
Garmin Nuvi 1490T Speaker Replacement
Qué necesitas
  1. Garmin Nuvi 1490T Speaker Replacement, Front Frame Panel: paso 1, imagen 1 de 1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Speaker Replacement: paso 2, imagen 1 de 1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Speaker Replacement: paso 3, imagen 1 de 2 Garmin Nuvi 1490T Speaker Replacement: paso 3, imagen 2 de 2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: paso 4, imagen 1 de 3 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: paso 4, imagen 2 de 3 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: paso 4, imagen 3 de 3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Speaker Replacement: paso 5, imagen 1 de 3 Garmin Nuvi 1490T Speaker Replacement: paso 5, imagen 2 de 3 Garmin Nuvi 1490T Speaker Replacement: paso 5, imagen 3 de 3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Speaker Replacement, Speaker: paso 6, imagen 1 de 2 Garmin Nuvi 1490T Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Carefully move the display out of the way of the speaker revealing the blue and black cord from the speaker.
  7. Garmin Nuvi 1490T Speaker Replacement: paso 7, imagen 1 de 2 Garmin Nuvi 1490T Speaker Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, gently clamp onto the white plastic end of the speaker connector.
    • Remove it by pulling slightly towards the speaker.
  8. Garmin Nuvi 1490T Speaker Replacement: paso 8, imagen 1 de 3 Garmin Nuvi 1490T Speaker Replacement: paso 8, imagen 2 de 3 Garmin Nuvi 1490T Speaker Replacement: paso 8, imagen 3 de 3
    • Wedge a nylon spudger into the crevice to begin to dislodge it from the body.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Slide the tool around the perimeter to fully dislodge the speaker.
Conclusión
Ricardo Solis
Miembro Desde 01/20/16
1,037 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 15-2, Remmell Spring 2016 Miembro de USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 254
