Saltar al contenido principal
Garmin Nuvi 1390LMT Battery Replacement
Qué necesitas
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: paso 2, imagen 1 de 2 Garmin Nuvi 1390LMT Battery Replacement: paso 2, imagen 2 de 2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: paso 3, imagen 1 de 1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: paso 4, imagen 1 de 2 Garmin Nuvi 1390LMT Battery Replacement: paso 4, imagen 2 de 2
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: paso 5, imagen 1 de 1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: paso 6, imagen 1 de 2 Garmin Nuvi 1390LMT Battery Replacement: paso 6, imagen 2 de 2
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: paso 7, imagen 1 de 1
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: paso 8, imagen 1 de 2 Garmin Nuvi 1390LMT Battery Replacement: paso 8, imagen 2 de 2
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
Linea de Meta
3 personas más completaron esta guía.
Trey Ulsh
Miembro Desde 10/22/15
537 Reputación
3 Guías creadas
Equipo
Montana Tech, Team 10-4, Shirk Fall 2015 Miembro de Montana Tech, Team 10-4, Shirk Fall 2015
MTUM-SHIRK-F15S10G4
5 Miembros
3 Guías creadas
Un comentario
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 3,751
