Saltar al contenido principal
Introducción
In this guide the repairer replaces the LCD display of the device by carefully prying apart the components with one's hands.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • None
Estimated Duration: 5 minutes
  1. Unscrew the two screws on the antenna unit using a torc-head screwdriver. The Torx-Head Screws' size is T-5, which is about 1.5mm.
    • Unscrew the two screws on the antenna unit using a torc-head screwdriver.
    • The Torx-Head Screws' size is T-5, which is about 1.5mm.
    • Gently pry open the antenna unit with your fingers.
    • Be careful and try not to damage the small plastic tab.
  2. Slide out the inner casing attached to the antenna body. Remove the rotating joint connecting the antenna casing to the main device: Squeeze tweezers into the shown location and compress the spring.
    • Slide out the inner casing attached to the antenna body.
    • Remove the rotating joint connecting the antenna casing to the main device:
    • Squeeze tweezers into the shown location and compress the spring.
    • Lift out the outer casing while keeping the spring compressed.
    • watch out, as the spring loaded portion may fly out unexpectedly.
  3. Using a torx-head screwdriver, unscrew the two revealed screws that connect the front and back of the device.
    • Using a torx-head screwdriver, unscrew the two revealed screws that connect the front and back of the device.
  4. Insert the plastic opening tool into the  center of the edge as shown in first picture. Slide the plastic opening tool along the central gap of device, making sure that each edge is free, as shown in the second picture. Slide the plastic opening tool along the central gap of device, making sure that each edge is free, as shown in the second picture.
    • Insert the plastic opening tool into the center of the edge as shown in first picture.
    • Slide the plastic opening tool along the central gap of device, making sure that each edge is free, as shown in the second picture.
  5. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  6. Detach the front display from the back panel of the device. Detach the front display from the back panel of the device. Detach the front display from the back panel of the device.
    • Detach the front display from the back panel of the device.
  7. Using tweezers, gently lift the microphone from its resting position to fully separate the device into two parts. Finally, remove the screw that connects the motherboard to the back casing with a 3mm head driver.
    • Using tweezers, gently lift the microphone from its resting position to fully separate the device into two parts.
    • Finally, remove the screw that connects the motherboard to the back casing with a 3mm head driver.
  8. After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  9. Hold the front panel plastic and screen as shown.
    • Hold the front panel plastic and screen as shown.
    • Gently apply pressure on the left and top left corner to allow the screen to come out of the plastic shell.
  10. Once the top-left corner is out, carefully start detaching the bottom of the screen, starting from the bottom left.
    • Once the top-left corner is out, carefully start detaching the bottom of the screen, starting from the bottom left.
  11. Finally, gently pull the screen out of the right side of the plastic shell.
    • Finally, gently pull the screen out of the right side of the plastic shell.
  12. The screen should now be completely detached.
    • The screen should now be completely detached.
    • Insert new, functional display screen.
Conclusión
Una persona más ha completado esta guía.
Matt West
Miembro Desde 18/04/13
22 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-65, Johann Spring 2013 Miembro de Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 482
