Saltar al contenido principal
Garmin GPSmap 60CSx Screen Replacement
Qué necesitas
  1. Garmin GPSmap 60CSx Screen Replacement, Back Cover and AA Batteries: paso 1, imagen 1 de 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Screen Replacement: paso 2, imagen 1 de 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Screen Replacement: paso 3, imagen 1 de 2 Garmin GPSmap 60CSx Screen Replacement: paso 3, imagen 2 de 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Screen Replacement, Screen: paso 4, imagen 1 de 2 Garmin GPSmap 60CSx Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
  5. Garmin GPSmap 60CSx Screen Replacement: paso 5, imagen 1 de 1
    • Take the spudger and place it in the bottom right corner of the black PCB cover.
    • Use the spudger to pry the corner out. This will need to be done to all four corners of the PCB cover.
    • It is best to do remove the bottom corners first.
    • Pull the PCB cover out of the GPSMap 60CSx.
  6. Garmin GPSmap 60CSx Screen Replacement: paso 6, imagen 1 de 2 Garmin GPSmap 60CSx Screen Replacement: paso 6, imagen 2 de 2
    • Carefully use the spudger to lift the PCB a few centimeters.
    • Pull the PCB towards the bottom of the GPSMap 60CSx.
    • This will pull the other components out of the GPSMap 60CSx like the antenna and the screen.
  7. Garmin GPSmap 60CSx Screen Replacement: paso 7, imagen 1 de 3 Garmin GPSmap 60CSx Screen Replacement: paso 7, imagen 2 de 3 Garmin GPSmap 60CSx Screen Replacement: paso 7, imagen 3 de 3
    • Apply light pressure to the four white tabs that are holding the screen in place.
    • The screen will now come off the PCB.
  8. Garmin GPSmap 60CSx Screen Replacement: paso 8, imagen 1 de 1
    • Turn the PCB over so the screen connector is facing you.
    • Move the screen out of the way for access to the screen connector.
  9. Garmin GPSmap 60CSx Screen Replacement: paso 9, imagen 1 de 3 Garmin GPSmap 60CSx Screen Replacement: paso 9, imagen 2 de 3 Garmin GPSmap 60CSx Screen Replacement: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to pull the two white pins on the connector forward.
  10. Garmin GPSmap 60CSx Screen Replacement: paso 10, imagen 1 de 1
    • Remove the screen ribbon connector and screen.
Conclusión
4 personas más completaron esta guía.
2 comentarios
i have a 60csx and the battery bounces the liquid, can help me?
salvador2707 - Contestar
Thank you for these step by step detailed instructions.
jlciscorp - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 40
Todo El Tiempo: 4,617
