Saltar al contenido principal
Garmin GPSmap 60CSx Gasket Replacement
Qué necesitas
  1. Garmin GPSmap 60CSx Gasket Replacement, Back Cover and AA Batteries: paso 1, imagen 1 de 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Gasket Replacement: paso 2, imagen 1 de 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Gasket Replacement: paso 3, imagen 1 de 2 Garmin GPSmap 60CSx Gasket Replacement: paso 3, imagen 2 de 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Gasket Replacement, Gasket: paso 4, imagen 1 de 2 Garmin GPSmap 60CSx Gasket Replacement, Gasket: paso 4, imagen 2 de 2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Separate the back panel from the front.
  5. Garmin GPSmap 60CSx Gasket Replacement: paso 5, imagen 1 de 2 Garmin GPSmap 60CSx Gasket Replacement: paso 5, imagen 2 de 2
    • Remove the gasket.
    • Be careful to make sure the gasket is aligned correctly to ensure it is water proof.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 31
Todo El Tiempo: 1,650
