Saltar al contenido principal
Garmin GPSmap 60CSx Battery Terminal Replacement
Qué necesitas
  1. Garmin GPSmap 60CSx Battery Terminal Replacement, Back Cover and AA Batteries: paso 1, imagen 1 de 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Battery Terminal Replacement: paso 2, imagen 1 de 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Battery Terminal Replacement: paso 3, imagen 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: paso 3, imagen 2 de 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Battery Terminal Replacement, Battery Terminals: paso 4, imagen 1 de 1
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
  5. Garmin GPSmap 60CSx Battery Terminal Replacement: paso 5, imagen 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: paso 5, imagen 2 de 2
    • Place spudger behind the lower right battery terminal.
    • Push spudger behind the battery terminal to pop it out of place.
    • Now do the same on the bottom left side.
  6. Garmin GPSmap 60CSx Battery Terminal Replacement: paso 6, imagen 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: paso 6, imagen 2 de 2
    • Grab the now loose battery terminals and pull them from the GPSMap 60CSx.
  7. Garmin GPSmap 60CSx Battery Terminal Replacement: paso 7, imagen 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: paso 7, imagen 2 de 2
    • Flip the back panel over to expose the backs of the top battery terminals.
    • Use a metal spudger to remove the glue that covers them.
  8. Garmin GPSmap 60CSx Battery Terminal Replacement: paso 8, imagen 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: paso 8, imagen 2 de 2
    • Flip the back panel back over to view the battery compartment.
    • Place the spudger behind one of the top remaining battery terminals.
    • Push the spudger down and pop the battery terminal out of place.
    • Repeat with the remaining battery terminal.
Conclusión
9 comentarios
What did you use to replace the contacts?
Austin Chopra - Contestar
Where can I buy replacement terminals?
Mitch - Contestar
Mitch, Garmin just told me they do no sell replacement terminals for this 60CSx. Were you able to find any?
Ernie Sammons -
Where can I find replacement battery terminals for a
Garmin 60CS4?
Sonny Pierce - Contestar
Where can I find replacement battery terminals for a Garmin Map76CS?
Paul - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 32
Ultimos 30 días: 160
Todo El Tiempo: 9,056
