Saltar al contenido principal
Garmin Forerunner 405 Button Replacement
Qué necesitas
  1. Garmin Forerunner 405 Button Replacement, Unscrew backing: paso 1, imagen 1 de 1
    • Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
  2. Garmin Forerunner 405 Button Replacement, Separate Component: paso 2, imagen 1 de 1
    • Pull the backing off the watch.
  3. Garmin Forerunner 405 Button Replacement, Separate: paso 3, imagen 1 de 1
    • Pull the battery wires out from the motherboard slowly.
  4. Garmin Forerunner 405 Button Replacement, Unscrew: paso 4, imagen 1 de 1
    • Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
    • Lift the motherboard out of the watch.
  5. Garmin Forerunner 405 Button Replacement, Pull apart: paso 5, imagen 1 de 2 Garmin Forerunner 405 Button Replacement, Pull apart: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Push button in and pinch silver clip with tweezers.
    • Pull silver clip off the pin it is on.
    • Pull out button and replace.
Conclusión
Kyle Kiwczak
Miembro Desde 09/11/14
328 Reputación
3 Guías creadas
Equipo
2Guía Comentarios
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
vasiljevicic - Contestar
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
keithnbrauneckermil - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 3,760
