Saltar al contenido principal
Garmin Fenix 3 HR Motherboard Replacement
Qué necesitas
  1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 Garmin Fenix 3 HR Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Motherboard Replacement: paso 2, imagen 1 de 2 Garmin Fenix 3 HR Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful of the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Motherboard Replacement: paso 3, imagen 1 de 1
    • Disconnect this ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Motherboard Replacement: paso 4, imagen 1 de 2 Garmin Fenix 3 HR Motherboard Replacement: paso 4, imagen 2 de 2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should move freely.
  5. Garmin Fenix 3 HR Motherboard Replacement: paso 5, imagen 1 de 1
    • Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Motherboard Replacement: paso 6, imagen 1 de 1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Motherboard Replacement: paso 7, imagen 1 de 1
    • The battery is glued to the motherboard and will need pried off with a nylon spudger.
  8. Garmin Fenix 3 HR Motherboard Replacement: paso 8, imagen 1 de 1
    • Now attach battery to new motherboard and reassemble.
Conclusión
5 personas más completaron esta guía.
Jacob Smiley
Miembro Desde 03/26/18
277 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G6, Harley Spring 2018 Miembro de IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
3 Miembros
4 Guías creadas
2 comentarios
And where would one source replacement motherboard?
jonathan.hatchuel - Contestar
donde puedo encontras placa.madre reeemplazo????
luis zavala - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 4,747
