Saltar al contenido principal
Garmin Fenix 3 HR Battery Replacement
Qué necesitas
  1. Garmin Fenix 3 HR Battery Replacement, Battery: paso 1, imagen 1 de 2 Garmin Fenix 3 HR Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Battery Replacement: paso 2, imagen 1 de 3 Garmin Fenix 3 HR Battery Replacement: paso 2, imagen 2 de 3 Garmin Fenix 3 HR Battery Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful with the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Battery Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Proceed to disconnect the ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Battery Replacement: paso 4, imagen 1 de 2 Garmin Fenix 3 HR Battery Replacement: paso 4, imagen 2 de 2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should now move freely.
  5. Garmin Fenix 3 HR Battery Replacement: paso 5, imagen 1 de 1
    • Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Battery Replacement: paso 6, imagen 1 de 1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Battery Replacement: paso 7, imagen 1 de 1
    • The battery is glued to the motherboard and will need pried off using the nylon spudger.
  8. Garmin Fenix 3 HR Battery Replacement: paso 8, imagen 1 de 1
    • Now attach the new battery with adhesive and reassemble.
Conclusión
40 personas más completaron esta guía.
Victor Tanguy
Miembro Desde 03/26/18
1,329 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G6, Harley Spring 2018 Miembro de IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
3 Miembros
4 Guías creadas
29 comentarios
Does anybody do It in a fenix 5?
Fernando Alcaraz - Contestar
Same question. Fenix five /+ guide on the way?
Erik E123 -
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Asif Shafiq - Contestar
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
Andreas Kahl -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 110
Ultimos 30 días: 471
Todo El Tiempo: 66,000
