Saltar al contenido principal
Garmin Fenix 3 GPS Antenna Replacement
Qué necesitas
  1. Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: paso 1, imagen 1 de 2 Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: paso 1, imagen 2 de 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 GPS Antenna Replacement: paso 2, imagen 1 de 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 GPS Antenna Replacement: paso 3, imagen 1 de 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 GPS Antenna Replacement: paso 4, imagen 1 de 1
    • Set the watch face aside.
  5. Garmin Fenix 3 GPS Antenna Replacement, GPS Antenna: paso 5, imagen 1 de 1
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 GPS Antenna Replacement: paso 6, imagen 1 de 1
    • Carefully remove the antenna, and set it aside.
Conclusión
Una persona más ha completado esta guía.
8 comentarios
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Nico Baumgartner - Contestar
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
dusan.kosobud - Contestar
Hi did you find gps antenna
Abdessamad Faroque - Contestar
Could you please add a link where to buy the antenna?
marco475 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 39
Todo El Tiempo: 5,241
