Saltar al contenido principal
Garmin Fenix 3 Display Assembly Replacement
Qué necesitas
  1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 2 Garmin Fenix 3 Display Assembly Replacement, Display Assembly: paso 1, imagen 2 de 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Display Assembly Replacement: paso 2, imagen 1 de 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Display Assembly Replacement: paso 3, imagen 1 de 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Display Assembly Replacement: paso 4, imagen 1 de 1
    • Set the watch face aside.
Conclusión
4 personas más completaron esta guía.
3 comentarios
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - Contestar
I have the same question.
Nicolas Chartier -
How do you make sure ribbon connector is aligned correctly
Steven - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 31
Todo El Tiempo: 9,124
