Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If your watch face is damaged, cracked, or chipped, you can learn how to replace it using this guide. This guide involves simply unscrewing screws from the watch face and carefully disconnecting the screen’s ribbon cable from the motherboard. You will need a T6 Torx screwdriver and a spudger.
Partes
No se especificaron partes.
  1. Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face. Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Carefully lift the face off the watch base.
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Set the watch face aside.
    • Set the watch face aside.
Conclusión
2 personas más completaron esta guía.
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - Contestar
I have the same question.
Nicolas Chartier -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 27
Ultimos 30 días: 96
Todo El Tiempo: 6,181
