Introducción
If you find yourself on this guide, it means your battery is draining too quickly. In that case, it might be time to replace your battery. It is important to note that for this step you must remove the touch display and motherboard in order to access the battery. Therefore, the steps for this guide begin with taking off the touch screen followed by the motherboard.
Qué necesitas
Paso 1 Touch Display
Aviso: los pasos 1-3 provienen de una guía que está marcada como "En progreso".
Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
Repeat this process a second to ensure that the glue is becoming loose.
Paso 4 Motherboard
Aviso: los pasos 4-7 provienen de una guía que está marcada como "En progreso".
Herramienta utilizada en este paso:Tweezers$3.99-
Remove brown and green tape with angled tweezers
Un comentario
I have a Garmin 820. I've seen a video by NewLife2OldStuff on YouTube and they don't heat the seal. But I've tried their method and cant get the opening tool in the groove.
Is the removal of the screen on the 830 the same for the 820? It looks similar.
