Saltar al contenido principal
Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement
Qué necesitas
  1. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: paso 1, imagen 1 de 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: paso 1, imagen 2 de 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: paso 2, imagen 1 de 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: paso 2, imagen 2 de 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: paso 3, imagen 1 de 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: paso 3, imagen 2 de 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: paso 3, imagen 3 de 3
    • Take a metal spudger and use force to push the micro USB port out of its socket on the other end.
    • Use the metal spudger once again to use force and push the SIM card port out of its socket. This will allow you to remove this piece entirely and insert a new charging port into the same place.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 1,525
