Saltar al contenido principal
Garmin Edge 1000 Back Cover Replacement
Qué necesitas
  1. Garmin Edge 1000 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Garmin Edge 1000 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Back Cover Replacement: paso 2, imagen 1 de 2 Garmin Edge 1000 Back Cover Replacement: paso 2, imagen 2 de 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 43
Todo El Tiempo: 5,726
