Saltar al contenido principal
Garmin Drive 52 and Traffic Speaker Replacement
Qué necesitas
  1. Garmin Drive 52 and Traffic Speaker Replacement, Motherboard: paso 1, imagen 1 de 3 Garmin Drive 52 and Traffic Speaker Replacement, Motherboard: paso 1, imagen 2 de 3 Garmin Drive 52 and Traffic Speaker Replacement, Motherboard: paso 1, imagen 3 de 3
    • Pop the suction cup off of the device.
    • Unscrew the four T5 Torx screws on the back.
    • Carefully pry apart the front and back with a Jimmy.
  2. Garmin Drive 52 and Traffic Speaker Replacement: paso 2, imagen 1 de 1
    • With the top in hand, carefully apply pressure on the top of the screen to pop it out of the front of the case.
  3. Garmin Drive 52 and Traffic Speaker Replacement: paso 3, imagen 1 de 2 Garmin Drive 52 and Traffic Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the four Torx T5 screws.
    • Unplug the two connectors from the motherboard and lift it up and out.
  4. Garmin Drive 52 and Traffic Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Gently lift the speaker out.
Conclusión
Jason Wilson
Miembro Desde 10/26/22
388 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 1-2, Petersen Fall 2022 Miembro de UMass Dartmouth, Team 1-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G2
6 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 89
