Saltar al contenido principal
Garmin Dezl 760LMT Battery Replacement
Qué necesitas
  1. Garmin Dezl 760LMT Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Garmin Dezl 760LMT Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Battery Replacement: paso 2, imagen 1 de 3 Garmin Dezl 760LMT Battery Replacement: paso 2, imagen 2 de 3 Garmin Dezl 760LMT Battery Replacement: paso 2, imagen 3 de 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Battery Replacement: paso 3, imagen 1 de 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Battery Replacement, Battery: paso 4, imagen 1 de 2 Garmin Dezl 760LMT Battery Replacement, Battery: paso 4, imagen 2 de 2
    • This photo shows the use of a tool that is not ESD safe. Use a nylon spudger to complete this step.
    • Use a nylon spudger to pry the battery from the device.
    • During reassembly, place double-sided electrical tape under the battery before pressing it into its slot.
  5. Garmin Dezl 760LMT Battery Replacement: paso 5, imagen 1 de 2 Garmin Dezl 760LMT Battery Replacement: paso 5, imagen 2 de 2
    • Grasp the battery wire near the motherboard and lift upward to detach the connector.
Conclusión
6 personas más completaron esta guía.
Ryan Williams
Miembro Desde 09/28/16
763 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 4-2, Passmore Fall 2016 Miembro de USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Miembros
6 Guías creadas
2 comentarios
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
Pissedoff - Contestar
you have to be more careful with your stuff dude..
Bealphares Voluptarius -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 5,916
