Saltar al contenido principal
Garmin Dash Cam 20 Screen Replacement
Qué necesitas
  1. Garmin Dash Cam 20 Screen Replacement, Internal Assembly: paso 1, imagen 1 de 2 Garmin Dash Cam 20 Screen Replacement, Internal Assembly: paso 1, imagen 2 de 2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Screen Replacement: paso 2, imagen 1 de 2 Garmin Dash Cam 20 Screen Replacement: paso 2, imagen 2 de 2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Screen Replacement: paso 3, imagen 1 de 2 Garmin Dash Cam 20 Screen Replacement: paso 3, imagen 2 de 2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Screen Replacement: paso 4, imagen 1 de 2 Garmin Dash Cam 20 Screen Replacement: paso 4, imagen 2 de 2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Screen Replacement: paso 5, imagen 1 de 3 Garmin Dash Cam 20 Screen Replacement: paso 5, imagen 2 de 3 Garmin Dash Cam 20 Screen Replacement: paso 5, imagen 3 de 3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Screen Replacement: paso 6, imagen 1 de 3 Garmin Dash Cam 20 Screen Replacement: paso 6, imagen 2 de 3 Garmin Dash Cam 20 Screen Replacement: paso 6, imagen 3 de 3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Screen Replacement, Screen: paso 7, imagen 1 de 3 Garmin Dash Cam 20 Screen Replacement, Screen: paso 7, imagen 2 de 3 Garmin Dash Cam 20 Screen Replacement, Screen: paso 7, imagen 3 de 3
    • Use the Phillips screwdriver to remove the four 5mm screws.
  8. Garmin Dash Cam 20 Screen Replacement: paso 8, imagen 1 de 2 Garmin Dash Cam 20 Screen Replacement: paso 8, imagen 2 de 2
    • Use the metal spudger to remove metal plate from device. This will reveal the screen.
  9. Garmin Dash Cam 20 Screen Replacement: paso 9, imagen 1 de 3 Garmin Dash Cam 20 Screen Replacement: paso 9, imagen 2 de 3 Garmin Dash Cam 20 Screen Replacement: paso 9, imagen 3 de 3
    • Use the metal spudger to remove screen from device.
  10. Garmin Dash Cam 20 Screen Replacement: paso 10, imagen 1 de 1
    • The screen is now detached.
Conclusión
Una persona más ha completado esta guía.
Jesse Hillman
Miembro Desde 10/04/16
757 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 2-1, Cagle Fall 2016 Miembro de USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 470
