Saltar al contenido principal
Garmin Dash Cam 20 Motherboard Replacement
Qué necesitas
  1. Garmin Dash Cam 20 Motherboard Replacement, Internal Assembly: paso 1, imagen 1 de 2 Garmin Dash Cam 20 Motherboard Replacement, Internal Assembly: paso 1, imagen 2 de 2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Motherboard Replacement: paso 2, imagen 1 de 2 Garmin Dash Cam 20 Motherboard Replacement: paso 2, imagen 2 de 2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Motherboard Replacement: paso 3, imagen 1 de 2 Garmin Dash Cam 20 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Motherboard Replacement: paso 4, imagen 1 de 2 Garmin Dash Cam 20 Motherboard Replacement: paso 4, imagen 2 de 2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Motherboard Replacement: paso 5, imagen 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 5, imagen 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Motherboard Replacement: paso 6, imagen 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 6, imagen 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Motherboard Replacement, Motherboard Components: paso 7, imagen 1 de 2 Garmin Dash Cam 20 Motherboard Replacement, Motherboard Components: paso 7, imagen 2 de 2
    • This step shows the use of an incorrect tool. Always use an ESD safe tool, like a nylon spudger, when working with delicate internal components.
    • Use the nylon spudger to pry the corner of the case off of the motherboard.
  8. Garmin Dash Cam 20 Motherboard Replacement: paso 8, imagen 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 8, imagen 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 8, imagen 3 de 3
    • Remove the metal case off of the motherboard.
  9. Garmin Dash Cam 20 Motherboard Replacement: paso 9, imagen 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 9, imagen 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove the battery connection.
  10. Garmin Dash Cam 20 Motherboard Replacement: paso 10, imagen 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 10, imagen 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 10, imagen 3 de 3
    • Remove the three 5 mm screws using the Torx T5 screwdriver.
  11. Garmin Dash Cam 20 Motherboard Replacement: paso 11, imagen 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 11, imagen 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 11, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the connector on the top right of the motherboard.
  12. Garmin Dash Cam 20 Motherboard Replacement: paso 12, imagen 1 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 12, imagen 2 de 3 Garmin Dash Cam 20 Motherboard Replacement: paso 12, imagen 3 de 3
    • Remove the motherboard from the case and flip to reveal SD connection.
    • Use tweezers to remove the connector next to the SD card slot.
  13. Garmin Dash Cam 20 Motherboard Replacement: paso 13, imagen 1 de 1
    • The motherboard is now removed aside from the copper strip and its connector.
    • Disconnect from the front case and the copper strip.
Conclusión
Jesse Hillman
Miembro Desde 10/04/16
757 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 2-1, Cagle Fall 2016 Miembro de USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 815
