Saltar al contenido principal
Introducción
In this guide there are delicate parts that will very easily break under tension. Keep this in mind as your move forwards.
Partes
No se especificaron partes.
  1. Remove the six T5 Torx 6.32mm screws securing the back cover to the watch. Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
    • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
  2. Remove the back cover carefully.
    • Remove the back cover carefully.
    • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
  3. Remove the orange gasket.
    • Remove the orange gasket.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the screen and motherboard assembly from the case.
    • Remove the screen and motherboard assembly from the case.
  6. Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
    • Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
  7. Remove the screen from the golden metal clip.
    • Remove the screen from the golden metal clip.
  8. Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
    • Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
  9. Remove the connector from the motherboard by pulling it free at the base. Make sure to pull from the base of the connector wire, as it is very easy to rip the wire from the screen.
    • Remove the connector from the motherboard by pulling it free at the base.
    • Make sure to pull from the base of the connector wire, as it is very easy to rip the wire from the screen.
  10. Remove the screen from the motherboard.
    • Remove the screen from the motherboard.
    • Notice our tape retaining the connector to the screen. This is so easy to rip!
Conclusión
Evan Miller
Miembro Desde 21/03/18
214 Reputación
2 Guías creadas
Equipo
IUPUI, Team S4-G1, Baechle Spring 2018 Miembro de IUPUI, Team S4-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G1
3 Miembros
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 11
Todo El Tiempo: 109
