Introducción
This guide directs the user in removing the back cover and battery. Keep in mind that this replacement requires generous prying and a consideration of tiny and delicate parts.
Qué necesitas
On the back cover use a plastic opening tool to remove the green tape retaining the battery.
6 personas más completaron esta guía.
7 comentarios
If anyone is looking for the replacement battery for the Approach S2 it can be found here:
Replacement Battery for Garmin Approach S2
It also included the T5 Torx and Opening Tools that are needed.
Step 6 shows 2 red wires each with a free end. One of these red wires has the non free end connected to the charging circuit terminal but there is no mention in Step 6 of disconnecting this wire or where the free end is connected to.
This is a great tutorial for the S2. In my case I accidentally dropped one metal shroud (referred to in Step 5). I scoured the area on my hands and knees to no avail. Can you direct me to where I might obtain this part?or perhaps the entire connector? Thank you….
Hi, Where the !&&* Can I buy a Replacement Battery for The Garmin S2 Golf watch.????.
Gregory, I got my replacement via Amazon (UK). Battery came from Germany in about 1 week. Not cheap, but a lot cheaper than a new watch.
