Saltar al contenido principal
GameStop GS3 GameCube Controller joysticks replacement
Qué necesitas
  1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: paso 1, imagen 1 de 2 GameStop GS3 GameCube Controller joysticks replacement, Joysticks: paso 1, imagen 2 de 2
    • Loosen and remove the 6 screws located on the back of the controller using your Phillips Screwdriver.
  2. GameStop GS3 GameCube Controller joysticks replacement: paso 2, imagen 1 de 1
    • Carefully pry apart the top and bottom covers.
  3. GameStop GS3 GameCube Controller joysticks replacement: paso 3, imagen 1 de 3 GameStop GS3 GameCube Controller joysticks replacement: paso 3, imagen 2 de 3 GameStop GS3 GameCube Controller joysticks replacement: paso 3, imagen 3 de 3
    • After separation, locate the rumble motor that is attached to the bottom cover of the controller.
    • Loosen and remove the 2 screws that are holding the rumble motor in place.
    • Lift and remove the rumble motor from the case.
  4. GameStop GS3 GameCube Controller joysticks replacement: paso 4, imagen 1 de 3 GameStop GS3 GameCube Controller joysticks replacement: paso 4, imagen 2 de 3 GameStop GS3 GameCube Controller joysticks replacement: paso 4, imagen 3 de 3
    • On the top cover of the controller, locate the green portion of the motherboard.
    • Loosen and remove the 1 screw in the upper left side of the green motherboard.
    • Turn the green motherboard over and attached to the motherboard will be the yellow c-stick.
    • Firmly, but carefully, pull the c-stick off, and clean around the area before reattaching or replacing the c-stick.
    • After cleaning or replacing the c-stick, reattach the green motherboard piece to the orange motherboard piece.
  5. GameStop GS3 GameCube Controller joysticks replacement: paso 5, imagen 1 de 3 GameStop GS3 GameCube Controller joysticks replacement: paso 5, imagen 2 de 3 GameStop GS3 GameCube Controller joysticks replacement: paso 5, imagen 3 de 3
    • Finally, loosen and remove the 2 screws located on the orange motherboard.
    • Pull up and remove the motherboard from the top cover. Then turn the motherboard over.
    • Locate the gray joystick that is attached to the left side of the motherboard.
    • Similarly to the yellow c-stick, firmly, but carefully, pull the gray joystick off, and clean around the area before reattaching or replacing the joystick.
Conclusión
Equipo
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 27
Todo El Tiempo: 1,052
