Saltar al contenido principal
GameStop GS3 GameCube Controller Motherboard Replacement
Qué necesitas
  1. GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Open the controller by unscrewing the screws located on the back panel
    • Separate the two halves of the controller.
  2. GameStop GS3 GameCube Controller Motherboard Replacement: paso 2, imagen 1 de 3 GameStop GS3 GameCube Controller Motherboard Replacement: paso 2, imagen 2 de 3 GameStop GS3 GameCube Controller Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the rumble-pack by unscrewing the screws located on on either side.
    • Remove the rumble pack to fully separate the two halves of the controller
  3. GameStop GS3 GameCube Controller Motherboard Replacement: paso 3, imagen 1 de 3 GameStop GS3 GameCube Controller Motherboard Replacement: paso 3, imagen 2 de 3 GameStop GS3 GameCube Controller Motherboard Replacement: paso 3, imagen 3 de 3
    • Disconnect the motherboard from the front half of the controller by unscrewing the small screws around its perimeter.
    • The motherboard should separate and lift right out from the front half.
Conclusión
John Harrison
Miembro Desde 10/28/16
213 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 667
