Saltar al contenido principal
GameSir T4 Pro Motherboard Replacement
Qué necesitas
  1. GameSir T4 Pro Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 GameSir T4 Pro Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 GameSir T4 Pro Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the following screws on the back case using a Phillips screwdriver:
    • Two 9.2 mm
    • Two 11.3 mm
    • Insert an opening tool in the seam between the front and back case.
    • Pry around the perimeter until the back case releases.
  2. GameSir T4 Pro Motherboard Replacement: paso 2, imagen 1 de 2 GameSir T4 Pro Motherboard Replacement: paso 2, imagen 2 de 2
    • Disconnect the USB-C charger with tweezers.
    • Do not pull on the wires.
  3. GameSir T4 Pro Motherboard Replacement: paso 3, imagen 1 de 1
    • Gently pry the battery off of the motherboard, with care not to bend the cell.
    • The battery is secured with adhesive. If the adhesive is stubborn, apply a small amount of high-concentration alcohol under the battery to loosen the adhesive.
    • Grip the white battery connector with tweezers and pull it directly out of its motherboard port.
  4. GameSir T4 Pro Motherboard Replacement: paso 4, imagen 1 de 2 GameSir T4 Pro Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the three 7.1 mm Phillips #0 screws from the motherboard.
    • Remove the two 7.1 mm Phillips #0 screws that secure the trigger assemblies.
  5. GameSir T4 Pro Motherboard Replacement: paso 5, imagen 1 de 1
    • Lift the motherboard out of the controller.
Conclusión
Una persona más ha completado esta guía.
Yamini Sri
Miembro Desde 04/01/24
355 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-2, Harley Spring 2024 Miembro de IUPUI, Team 1-2, Harley Spring 2024
IUPUI-HARLEY-S24S1G2
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 124
