Saltar al contenido principal
GameSir G7 SE Rumble Motor Replacement
Qué necesitas
  1. GameSir G7 SE Rumble Motor Replacement, Interior face plate: paso 1, imagen 1 de 1
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Rumble Motor Replacement: paso 2, imagen 1 de 2 GameSir G7 SE Rumble Motor Replacement: paso 2, imagen 2 de 2
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Rumble Motor Replacement: paso 3, imagen 1 de 2 GameSir G7 SE Rumble Motor Replacement: paso 3, imagen 2 de 2
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
  4. GameSir G7 SE Rumble Motor Replacement, Rumble Motor: paso 4, imagen 1 de 1
    • Once you can see the internals of the controller, you need to remove the plug for the rumble motors. This plug is easy to remove and can be pulled straight out using your hands.
    • Use a pair of small pliers if you have difficulties.
  5. GameSir G7 SE Rumble Motor Replacement: paso 5, imagen 1 de 2 GameSir G7 SE Rumble Motor Replacement: paso 5, imagen 2 de 2
    • Once the plug is removed, you can easily pull out the rumble motor.
    • There is a left and right rumble motor, so be careful when replacing them. It is easy to differentiate them visually. Look for the size of the weights on the bottom; they will be different.
Conclusión
Memphis Collins
Miembro Desde 01/23/24
281 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 31
Todo El Tiempo: 60
